RX330 Back Wiper Blade Replacement
Old 02-04-08 | 02:47 PM
travelgal's Avatar
travelgal
Default RX330 Back Wiper Blade Replacement
Hello to all.
Need to replace the back wiper blade. Is it possible to change the arm, like the front blades, or is it easy enough to reinsert the rubber piece? I've contacted the dealership, but live a few hours away so won't be going in that direction for several weeks at least. I need a step by step on how to get this fixed. Right now the blade is unuseable since the rubber piece is just hanging there, and we're getting snow.
thanks for your help.
Old 02-04-08 | 03:17 PM
lexuslover's Avatar
lexuslover
MultiTasking Mom
i believe it changes out like the rest of the wiper blades. you just remove the old rubber and put in the new. you shouldn't have to replace the arm unless you broke it somehow.
this is what you need:
http://www.lexus-parts.com/parts_detail.asp?id=73060
sewell lexus is a club lexus vendor. you can use code CL911M to get an add'l 10% off.
p.s. welcome to Club Lexus
Old 02-04-08 | 05:18 PM
salimshah's Avatar
salimshah
Be careful as a worn wiper can potentially scratch the glass.
These are generic instructions for wiper insert.
On some [rx 300 front wipers and GS400 and SC400] the wiper blade can be separated from the arm by squeezing a lock release and sliding the wiper arm out. In any case the procedure to replace the insert is the same as listed below.
Lift the arm away from the glass.
Typically the bottom of the insert has a lock (looks like an arrow). Give it a gentle but firm yank and the rubber piece will slide out.
There are two metal strips that give tension and rigidity to the insert, and can be sharp.
Pay attention to them as they will practically fall off once you have the insert out.
Remember to transfer them to the new insert the way they come off (they have a curve to match the glass).
Insert the new setup making sure the claws of the arm are in the right groove.
Give it the last bit of push to snap in the lock head.
Make the final check to see all claws are in their groove and the insert slides smoothly as you arch and straighten the wiper.
Salim
Old 02-04-08 | 06:23 PM
tjain's Avatar
tjain
There is a new discount code to save more @ sewell lexus : Club Lexus global 15% discount code – through 3/01/2008 – Promo Code “ClubLexus”
Old 02-04-08 | 06:51 PM
travelgal's Avatar
travelgal
Default RX330 Back Wiper Blade Replacement Reply to Thread
Thanks to all for the information and for the discount codes.
I'll give you a follow-up when I'm done.
Old 02-05-08 | 08:17 AM
mandyfig's Avatar
mandyfig
Salim had it right. Here's the trick: To flip the wiper up, you will need to pry off the base cap (end of wiper). Then you can flip the wiper and then follow generic procedure. I learned this the last time I tried to change it. Good luck.
Old 02-05-08 | 08:19 AM
mandyfig's Avatar
mandyfig
No need to replace the wiper arm, unless you had issues with the wiper...there was a TSB on this. They changed the wiper arm. Normally, changing the insert will do the trick.
Old 02-12-08 | 09:32 AM
CarNutTO's Avatar
CarNutTO
Can someone please tell me how to do this on an '05. I bought a new wiper arm a couple of weeks ago and have been unable to get the cap off. I tried prying apart the upper and lower parts of the bottom of the cap, but still couldn't get it to lift off. I don't want to break it!
Old 02-12-08 | 10:08 AM
mandyfig's Avatar
mandyfig
Gently slide a taped flat screw driver and pry the base cover off. It should just pop off. I will try doing it tonight with PICS.....
Old 02-12-08 | 10:09 AM
mandyfig's Avatar
mandyfig
Then you can unbolt the old wiper arm...or else, swing it out to replace the wiper insert.
Old 02-12-08 | 02:58 PM
dhamaka127's Avatar
dhamaka127
Has anyone used a RainX wiper?
http://www.buyrainx.com/view_cart.cf...TOKEN=23032521
I was just thinking about it for my next pair.
How long do they last also?
Old 02-12-08 | 04:05 PM
mandyfig's Avatar
mandyfig
I thought about getting the ICON blades from Bosch. They are buy one free one from PepBoys right now. Our RX wil take: 24" Dr $26 and 19" Pass $22. But I had purchased 2 sets of refills from Lexus...so I will stick to OEM for now.
Old 02-12-08 | 05:13 PM
KeysRx300's Avatar
KeysRx300
Default Windshield Wipers
I use to change all of my blades when they started streaking. But I found a tip in the detailing section of this web page. The blades can be cleaned with isopropyl alcohol. This removes the dirt that causes the streaking.
Since I started cleaning my blades. I havent replaced one wiper blade.
Old 02-12-08 | 05:44 PM
mandyfig's Avatar
mandyfig
I have to try this alcohol thing. Will it not make th erubber brittle after some time?
Old 02-12-08 | 05:49 PM
CarNutTO's Avatar
CarNutTO
Thanks. Where should I try sliding the screwdriver? Under the top of the cap or under the bottom "wings' of the cap?
