Dash lights coming on
Old 02-25-08, 05:36 AM
jer55
jer55's Avatar
Default Dash lights coming on
I have an 04 RX and the dash lights have started coming on intermittently. Has happened about 5 times now where the ABS, TPMS, etc will all come on shortly after starting or won't go off. If I turn the RX off & restart it, the problem is resolved. In the manual there seem to be several fuses relating to the dash lights. Anyone else have the problem, or can offer some suggestions? I've only got about 30k on it but the warranty has expired, so I would hate to take it in if it's something I can fix myself. Thanks all!
msgs350 (04-16-17)
Old 02-25-08, 11:31 AM
The G Man
The G Man's Avatar
I dont think its a fuse, sounds like some kind of sensor is defective.
Old 03-01-08, 03:36 AM
jer55
jer55's Avatar
Thanks for the info. Hopefully it won't cost too much to have it checked out.
Old 03-01-08, 10:21 AM
mandyfig
mandyfig's Avatar
Last I read, this was sign of a bad battery.....
Old 03-05-08, 12:22 PM
kirk200
kirk200's Avatar
Default Similar problem on our 2004 RX330
We have a 2004 RX330, which very recently also seems to be experiencing a similar problem - while driving (it has happened twice now) several dash lights come on: ABS, Brake, VSC, and "SS" (I think that's the traction/slip light - will check)... the car drives fine, and if you "reboot" it by shutting it off and then restart, all the lights go back out. I will put an ODB-II scanner on to check for engine codes this weekend and compare findings to my Lexus shop manuals. Will let you know what I find... hopefully something inexpensive, as our car is also now out of warranty too, even though the mileage is pretty low (<50K), we are the original/first owners...
Regards,
- Kirk
Old 03-05-08, 02:35 PM
timho
timho's Avatar
Not sure if this is gonna be helpful, but similar thing happened on my other vehicle (VW Passat) several years back. All the dash lights suddenly went on and/or went out but the car drove fine. In the end it got towed back to dealer because the car wouldn't start. Turned out the Instrument Cluster Module went bad. What the module does is to control all the dash lights and communicate to ECU and Immobilizer. It was covered by factory warranty but I think the repair bill was about $500.
Tim
Old 03-05-08, 06:27 PM
Grumpa72
Grumpa72's Avatar
I am not sure how this could be since the voltage that the car sees while driving is 14+ volts, the output voltage of the alternator. A fully charged battery will only show 12+ volts with the engine shut down. Therefore, the instrument cluster should think that the battery is fully charged.
Old 03-06-08, 02:04 AM
CK6Speed
CK6Speed's Avatar
Still could be a bad battery connection terminal. I had something very similar happen on my LS400. VSC, ABS lights would come on intermittently upon start up. Shut the car off and start again and more than likely the warning lights would not appear. Couldn't figure it out for a few weeks. Then I found my negative battery terminal slightly loose. Fixed that and I never had the problem again months after. I sold the car already so I can't confirm if the problem came back, but my friend that I sold the car to a few weeks ago hasn't mentioned anything so far.
Old 03-06-08, 05:16 AM
Grumpa72
Grumpa72's Avatar
[QUOTE=CK6Speed;3336021]Still could be a bad battery connection terminal. QUOTE]
That could be! To avoid this type of battery issue, I disconnect my battery cables annually and clean them and the battery top with baking soda (usual precautions of course) and then reconnect. I also spray on a protective product that helps reduce battery terminal corrosion.
Gary
palmdes1
IS - 1st Gen (2001-2005)
07-12-17 09:57 PM
rav018
08-27-09 12:46 PM
Chu821
04-06-06 06:09 PM
zachopp
10-22-05 01:17 PM
sc300wanabT
SC- 1st Gen (1992-2000)
08-01-01 05:59 PM
Quick Reply: Dash lights coming on
