2005 RX330 Ignition Key Help
My spare ignition key is not working. I suspect the battery might be bad. My question is if I open the key to change the battery will I lose the key memory program? Also my car is still under the 4 year warranty. Would the key be completely covered under the warranty?
My main key I use every day functions fine, and still has the original battery !
Thanks in advance,
Carl
Thanks in advance,
Carl
Yes, you are covered...run!= to the shop!
chuckb
11-20-07 09:46 PM
