Removed roof rack - where to get rubber strips?
Since I never use the roof rack, I removed them and was surprised how easy it was. Now that I have them off, I'm wondering where to get the rubber weathering strips to fill the gap where the screws used to go. Order from Lexus/Toyota or any other ideas? Thanks!
Darn, I do recall the thread too. You may want to check with one of our Lexus sponsers for the parts to do that. Suggest you contact Sewell Lexus parts department, they've been great, good prices and fast shipment. They are in TX I believe and last time I contacted them and ordered parts, I had the shipment in a couple of days.
This must be the thread...
http://sr1.clublexus.com/forums/show...=weather+strip
Seems like people just bought the rubber insert molding and cut it up to fit in place.
Thanks for the recommendation on Sewell Lexus. I will check them out.
About $50 / set
In another thread someone posted the full length left & right p/n's -- via Sewell they cost about $25 each.
"Lexus OEM Roof Drip Side Finish Moulding Center."
http://www.lexus-parts.com/assembly....l=215&year=168
Part Numbers: LH & RH
75551-48041
75552-48041
(Thanks to CL members sportsfan8 & CK6Speed)
75551-48041
75552-48041
Roof Rack Inserts
I removed the roof rack from my RX350 the first week I had the car.
I didnt go with the rubber inserts. I ordered a pair of the 6 foot long hard plastic pieces from Sewell. It is the piece that is used on the multipanel roofs with no roof rack.
Took about 3 minutes to install.
75551-48041
75552-48041
75551-48041
75552-48041
Those part numbers now show as being $90.78 each before discount -- $77.16 after discount. Quite a bit more than $25 each stated a month ago.
Anyone come up with different numbers or a different source?
