Halogens to HIDs on 2007 RX350
I'm interested in getting HIDs to replace the boring stock halogens that came with the car. However i'm looking for an easy way to do it. Does anyone know if there are any simple "Plug and play," so to speak, HIDs for the RX350. If so, where at?
Thanks
Thanks
You have to make sure the plug and play kit draws less than 10 amp per side when starting up, I believe McCullon and phillips are couple of the brands that has that draw. You can play it safe and use the battery harness and relays.
