Question On Modifying The Rx 350
#31
thanks everyone. I was not expecting BMW handling or cornering, just to improve it. Better steering and handling response and get rid of the boaty feel on the road, I would be happy if it felt like the 08 MDX not even FX35..
#32
I was on the business trip on HK and I saw it. So, I bought it and ship it back to US. I was paying around $350/set at that time and it was Oct 2006.
There is another link to this kit too from Japan. Here is the link;
http://toyota.jp/harrier/dop/package/index.html
Good luck!
Good luck!
#33
Good luck!
Good luck!
It looks so much better all the same color as the vehicle.
#34
Good luck!
Good luck!
#36
$350-$450.00 sounds like a pretty fair price to me.
I want to email them but I can't figure out which is the email... lol
#37
#38
I paid $600.00 for painting to match my RX. According to the body shop, it was tri-stages paint which I have no clue. It has something to do with the glitter inside the paint (Welcome to the world of Lexus).
Anyway, I have found a US website which has lot of these kits. You might want to call them up. Here is the link;
http://www.edozone.com/Lexus/lexus_index.htm
Good luck!
Good luck!
#39
I'm totally with you on improving the handling of the RX just a bit with minor mods like bigger wheels, tires, springs, etc. Keep us updated on what you'll be doing. I also owned a BMW and sadly, I think I'm now spoiled on the pure handling aspect of driving a BMW. Unfortunately, there's a trade-off for everything. I want a reliable car with great interior that drives like a BMW... is that too much to ask?!
#41
looks like you have about 20mm of space left between the inner edge of wheel and the perch. i did some calculation and with a 9.5in width +12 i would be 5mm closer the to perch. which leaves maybe 15mm of room, but then i have to remember about the tire..hmm
is the edge of your rim flush with the fender or is it in a little?
if you can take more pics or rear and the front i would GREATLY appreciated it.
i wonder is 8.5 F and 9.5 R would work or 9.5 all the way around?? anyone knows??
#44
i forget the rx offset but i think its mid30s. if the offset of the mmr wheels are +35 9.5R. you would need a 20-25mm spacer to clear strut/spring perch. for the front 8.5 or 9.5 you will have enough clearence from strut and it should be flush with fender.
#45
The offset on stock is 35mm. I will tell you I put on 19x8 with a 40mm offset and I needed a 5mm spacer on the rear because it was rubbing on the inside of the tire which are 255x50's. CK6Speed has 20x8.5 with 255x50's and I think his are as wide or big as you can go without modifying it to fit. His looks very good but any wider at all would be to wide. I believe his offset was a +20mm. All offsets mentioned above are all +.
