07 RX350 Gas Question
Ive owned my RX for just over a year. I have about 14k miles on it. Over the past month or so i have noticed a big decrease in what the cruising range is. I used to get around 312 miles to empty on a full tank. Now im consistently getting 265 miles to empty. Ive used the same gas from the same place and my driving habits have not changed. The basic to and from work and running around town. I use 93 octane always. Ive never used regular. I have noticed that I am filling up the tank more often. I even tried a different gas station thinking i was getting ripped off. Any ideas why this is happening?
Has to be the air pressure.
My TPM light was going on & off by itself prior to the oil change , all is well now.
The toyota dealer found that one tire had 29 PSi instead of 32 PSI.
By my calculations I have been averaging about 14 mpg X 19 = 266 which is about what my computer said today after I filled up. I would expect that to be more on a trip but I have been driving in stop and go city traffic for the most part of my driving so far.
Thanks guys. I will check the tire pressure. What psi should i have in there? 32psi? I have the 18" wheels. At what point does the TPM light come on?
Catdaddylo - I will definitely try what you said and let you know.
As suggested, doing an actual calculation of your mpgs is a far more accurate method of determining your mileage. Anything else is just an estimate.
Gary
You do not have to burn up all of the gas in the tank. You start out with a full tank which is approximately 19 gallons. You drive your car until you fill up with gas again. It does not matter if you burned 5 gallons or 15 gallons or 19 gallons. You fill up your tank again and do the math of miles driven divided by the number of gallons of gas used multiplied by 19 and see how close the computer comes to the actual miles calculated by your numbers. Is this as exact as seeing how far you drive until you run out of gas ? No, but you would not be off much where it would make any difference. The point is that Drew was seeing 312 miles and is now seeing 265 miles to empty and wants to know what is wrong. I am trying to show that perhaps nothing is wrong by doing a hand calculation on his driving habits. Perhaps Drew did more city driving, stop and go, short trips than he realized , thus he gets the 265 mile reading where the opposite is true where he got the 312 mile reading.
Well,after being a mechanic for a while,I got my cdl,and went over the road,(yes the big sleeper rig)anyway,in those big trucks we had two 250gallon tanks.The problem is it isnt useable gallons.you might only be able to use 210 of that fuel on each side.(due to length of the pick up tube)Now to check fuel mileage,what catdaddylo said applies.Btw,I found I get about 1mpg more than my computer tells me.Witch isnt bad.
Itsjerald
HS 250h Model (2010-2012)
07-01-13 07:40 AM
diablo1
08-28-06 02:35 PM
