rx 350 vs rx 400h
#31
The batteries we deal with are predominantly Gel-cell technology and the "acid" is recycled through certified agencies. There are some really strict laws governing battery (and the associated acid) disposal, both Federal and State. If you run afoul of them, it's not pretty and gets very expensive! In the EU the laws are even stricter in regards to disposal and the battery manufacturers are required, by law, to recycle one-for-one or face stiff fines.
#34
#38
Now you mentioned it, I did a bit of research. From Lexus.com: the RX400h is 1" longer and 2.4" taller than RX350. I have known about the taller part for a little while, but the fact that it is slightly longer as well is new for me.
RX 400h
Length (in / mm) 187.2 / 4,755
Width (in / mm) 72.6 / 1,844
Height (in / mm) 68.5 / 1,740
Wheelbase (in / mm) 106.9 / 2,715
Ground Clearance (in / mm) 7.1 / 180
Approach Angle 28.3 degrees
Departure Angle 24.3 degrees
Curb Weight (lb / kg) 4,365 / 1,980
Max Towing (lb / kg) 3,500 / 1,588 [5]
RX350
Length (in / mm) 186.2 / 4,729
Height (in / mm) 66.1 / 1,679
Ground Clearance (in / mm) Coil Suspension 7.48 / 190
Approach Angle, RAHC Normal 29.0 degrees
Departure Angle, RAHC Normal 23.5 degrees
Curb Weight (lb / kg) 4,090 / 1,855
RX 400h
RX350
