Trans plug leaking after fluid change?
I just changed the trans fluid in my RX330. I put the plug back in with no problem, no cross threading and I now see it is leaking. Do they have a gasket on them? It was kind of dark under there and I do not know if it fell out or something before I screwed it back in? Do they have a 1 time copper crush washer?
Thanks in advance.
Thanks in advance.
Yes there is crush washer. In a pinch you can use nylon/fabric/copper/aluminum. I always buy mine from the dealer.
Also set the right torque.
Salim
Salim
It has a crush washer. That is what I figured. I wondered since I change my own oil and very experienced. I guess I will have to dump the new oil in a clean container and re-use it. So I get 27 views and no one has experience except one guy? Tells you that not many either do there own work or don't change their fluid. I lost a trans in my RX300 at 98000 after buying one that apparantly was not taken care of.
Although some have re-used the old crush washers, I would advice against it. [if you plan to reuse, then buy the nylon type as they bounce back a bit]. Service manual says to replace it.
At the dealer the washer's run 90c or so. When you go through so much work and saving a large % of total cost .. throw in the washer and you will not have the drips.
There are 3 outcomes, washer stays with the bolt, falls in the drain pan or stays stuck on the engine side. Most of the time, the washer stays stuck to the engine for me and I have to pop it off with a blunt object.
Salim
Salim
Are you sure it is not the transfer case oil leak TSB?
I have the same problem with my ES330 that the dealer changed the fluid. It is a very small leak that is very intermittent. I took it back to the dealer and they said they could not find a leak. Several weeks later I noticed another drop on a piece of white cardboard I have kept under the car since this incident. I can take it back to the dealer or just try to tighten the plug my self. The plug takes a hex bolt. Does anybody have an idea of what size and what torque is needed for this plug ? I know I could take it back to the dealer but it sure would be a lot easier to just try to tighten it myself and then if it continued to leak I can take it back and ask that the job be done again with a new crush washer.
It is either 10 or 12mm for RX 36lb-ft for the drain plug.
A drop in 2 weeks will be not noticeable in the workshop. Once on the rack to check for leak, I would have expected them to re-torque it.
Replacing the crush washer is easy, but you will loose some fluid....[never reuse the drained fluid].
Salim
You do not have to drain all the fluid. You just have to work fast. Losen the plug, and pull it out while plugging it with something immediately, like a little rubber plug or a thumb. Then get the washer and plug ready, and stick it in fast. You might only lose a cup or two.
Been there, done that!
You can cut a hex key 1.5" and then use a socket. Or visit Harbor Freight for a whole set [light duty].
Salim
Salim
Mechanically, as long as you have enough fluid (above minimum) you are fine. At this rate you can last a whole lot of time and if you need to, you can top it of in between.
On the other hand, how do you feel about your Lexus marking its territory.
I would say keep an eye on how much fluid you leek. It just might crud over and seal itself.
Your call.
Thank you for the compliment about RX forum. It reflects on the members as well as the mods.
Salim
Your call.
Salim
The BMW has marked its territory on the driveway at home and the parking spot at work with ATF fluid from the power steering pump, coolant from water pump, brake fluid from master cylinder, etc. Everyone at work just smiles when they see me with the hood open an empty bottle of something on hand.
I have that pet, too. My 95 Camry!
BlueCrabby
RX - 1st Gen (1999-2003)
09-04-15 07:10 AM
cubbieblu7
IS - 1st Gen (2001-2005)
06-19-12 09:12 PM
