10k Maintenance
Jag,Benz and BMW use synthetic brake fluid and do not require service of the fluid for 100K miles. Maybe the quality of the brake components on those cars is of higher quality. As for the transmission fluid change I follow the manufactures rec. they designed and manufactured the car and I would think they would like you to have a car that is reliable for at least 100-150K miles. The coolant does not get changed until I think 100K. Remember the quality of the fluids (oil, brake, coolant) is far superior than just a few years ago. The dealers just want your money, and recommend additional service. I do not think the Lexus RX other components (body, interior etc.) will stand up to high mileage any way. I will dump it well with in the warranty period to eliminate any long term issues. Do as Lexus recommends to cover the warranty and save your money to purchase the new 2010 model as our RX models will look 10 years old when they release it. Three years or 30K miles for maximum trade, minimum loss.
Trade the RX at 3 years or 30K miles for maximum return, minimum loss and purchase a 2010 model as our RX models will look 10 years old when it is introduced. Do only the service that the manufacturer tells you to do. The stealership just wants to take your money. My Jag, Benz and BMW have all been maintained to the factory spec and I have had no maintenance related failures. I do not think the RX's body,paint and/or interior will not stand up well to high mileage even if over maintained.
We have an '04 RX330, but I feel this still applies. We had our transmission serviced at 60K (the dealer said not to change it at the 30K interval) and it definitely needed to be changed. At the 90K flush, the fluid looked much better. I cannot imagine what the fluid would look like at 100K.
IF, and that's a big "IF", the vehicle is equipped with Toyota "ATF - WS" - World Standard Automatic Transmission Fluid, it merely needs inspecting at 100K miles and is allegedly designed to last the life of the transmission under per TSB TC008-07. The TSB infers that all Lexus with automatics have used this fluid since 2004, but does not explicitly say so. I have an outstanding question to Lexus on that one. Having said that, I am skeptical of any ATF lasting that long. The stuff gets darn hot!
My 04 RX330 has Toyota Type IV fluid in it now and that's what the manual said to put in it.
I am not familiar with the ATF - WS, is that the same stuff?
Super Moderator
Actually, scratch that, I can speak for Mercedes. I just did a spot check of a 2002 C230 and 2007 E350, and both dictate brake fluid changes every two years. If you look up a Jaguar schedule, I guarantee they'll say the exact same thing. I'm afraid you're completely mistaken here.
Brake fluid is hygroscopic (water absorbing) not hydrophilic (correct spelling) (being able to dissolve in water). Just want to make it clear. I use only ATE brake fluid. My 300 TD wagon had over 425K miles on only one fluid change! My E class has had two brake fluid changes in 200K, no issues. My Z3 3.0 has had no brake fluid changes in 25K miles. Thinking about it, you are correct to change it. Minimal cost. I will purchase a one man top bleeder and will not even get dirty doing it.
Wow, wow. I just paid $130 for my "service" at 10000 for my '08 350. Unbelievable. I'm going to have to call toyota dealerships around here. I'm in boston.
100k, 10k, atf, bulletin, hygroscopic, included, lexus, lexusrx300dealer, maintenance, miles, rx330, scheduled, service, toyota, ws
