AC not Working
My battery got drained a week ago for not using my RX330 for couple of months, i have to jumped start . I found out just yesterday my AC not
working. Can someone help me . thx
When you turn the a/c on,do you hear the compressor kick in? i.e the idle of the car change? It`s possible your low in freon.You can also pop the hood,and see if the compressor clutch is working.
I don't hear the kickin of the compressor just the fan . by the way i don't think i have low freon cause the car has 5500 miles on it.
once a week.
The alternator can only replace a minor drain caused by starting and running your RX. The battery needs a full charge from a large battery charger. Take it to a shop that will charge it for an hour. If the A/C will not work after that, then have them disconnect the battery for 5/10 minutes and then retry the A/C. That should reset the computer. I've done that on other cars, but not a Lexus, so I'm not sure that it will work.
Uncharged battery will leave you stranded, so have that taken care of first.
Salim
I brought may RX to the dealer this morning and gave me a loaner car (have to fill up gas when you return it ). The repair Adviser called me and said that my AC condenser has a hole and no freon @ all , according
to them it got hit by rock / stone whatever....I asked him where is that condenser located at? he told me it is located in front of the radiator. The repair cost will be $1000 labor /parts. So i went back there and pick up my RX and told them i'll take my car for now and find out where is that condenser leaking cause my car is always in my garage and never seen that leaked under. Anyone of you there has idea how much gonna cost for AC condenser replacement ? i just need advise, cause $1000 looks high for me for
a repair. thx
a repair. thx
can someone tell me the location of the A/C condenser? is it infront of the radiator? just wondering how i got hit by rocks/stone. these part shouold be
hide or covered if it is prone to get hit.
The condenser radiates heat, the refrigerant is passed through pipes which have aluminum fins [very much like radiator for engine coolant]. The whole thing is exposed to raming air. This means it is exposed to flying rocks. The whole thing is not as big as the coolant radiator.
The whole thing is academic as the unit has been diagnosed with a puncture leak.
At this time, you can practically go auto-A/C shop and possibly shave off some cost.
Salim
Salim
Salim
Salim
I was thinking , becuase my battery got drained and i seldom used my car/ac
it might cause to the condenser to get stocked . My car has only 5500 miles on it rarely used. Another thing , when i turned on the A/C , there was no changes on the rpm.
Since you have lost the refrigerant, The compressor will not come-on.
The other thing about refrigerant loop is, you need to run the compressor once every week. There are rubber seals, which will dry out and you will leak the refrigerant if you do not run it.
Salim
Salim
