Outside temperature gauge
Hello all. I have an 04 RX330 with the navigation. My outside temperature guage is stuck at 122. I searched the RX forum to see if there was a reset. Does anybody know if there is a way to reset the temperature display or is this a dealer only repair? Thank you.
Crawl under the front bumper. The sensor [at least in RX300] is there. Look for dangling wires or crushed sensor. If you search the RX300 forum, Lexmex posted a picture of the sensor a while back.
I hope it is as simple as that!
Salim
Salim
Out of Warranty
Salim's right, the OAT sensor is mounted on the driver's side just below the front bumper - on the RX300. I think, but I'm not sure, that on the RX330, that display is taking a reading from your Mass Airflow Sensor in the intake.
If so, I much prefer the setup in the RX300, although it could often be confused by our July-August temperatures and heat reflection from a Texas blacktop road. I've seen 114° indicated on my RX300 on a hot day in North Texas. Real OAT was probably about 98°.
If your sensor is located on the MAF, you would think it would be throwing CEL codes all over the place. Any ideas?
Super Moderator
Ironically enough, the battery went dead. After I replaced the battery, the outside temp reading went back to normal. I assume that it was reset when there was no electricity.
Super Moderator
There used to be a quirk that I would get every so often with my RX300 where when I turned on the vehicle nothing would show up on the blue screen and I would have to disconnect the battery to get rid of the gremlins.
rmuthiah
12-01-19 11:24 AM
