Transfer Case Leak
Old 08-11-08, 07:25 PM
high_rpm
high_rpm's Avatar
Default Transfer Case Leak
I have a transfer case leak on my '04 RX330 with about 63k miles on it.
Appears to be coming from either the area where the silicone mated the iron and aluminum parts of the housing, or possibly from where the transfer case connects to the trans.
Am I correct to assume that the dealer will not fix this under warranty at my mileage?
Has anyone tried to repair this themselves? I've read a few of the postings with various transfer case leaks and they talk about removing the transmission...
Old 08-12-08, 05:31 AM
mandyfig
mandyfig's Avatar
Check it out, I bet you it is part of the powertrain warranty which goes to 70K miles......take it in.
Old 08-14-08, 11:19 AM
high_rpm
high_rpm's Avatar
You're right. It was covered under the 70k powertrain warranty. Good for us.
When I first saw the wet area, I cringed because I'm used to the Big 3 way of covering warranties where they basically try to stick it to you especially if you are technically beyond the 4/50k warranty.
Old 08-15-08, 10:15 AM
fud
fud's Avatar
mine was replaced at 18k...
DDLexus
IS F (2008-2014)
12
06-04-20 09:08 AM
BP1203
RX - 3rd Gen (2010-2015)
10-07-15 08:05 AM
babaganoos
10-30-13 09:21 AM
bwallace2
GX - 1st Gen (2003-2009)
04-15-10 01:00 PM
gazi001
RX - 1st Gen (1999-2003)
09-03-08 05:01 AM
Quick Reply: Transfer Case Leak
