Thumping noise when decelerating to 30km/h
Old 10-03-08, 06:24 PM
lebahawk
lebahawk's Avatar
Post Similar issue with my rx330
Originally Posted by mandyfig
Here's my original post.
https://www.clublexus.com/forums/sho...ighlight=clunk
I can describe the TSB and give you the part number, but I suggest you take it in and ask them to do the TSB.
Hi, I am having the same issue you experienced with my 04 Rx330 I took it to the dealer and they said its the trans line thats making this noise. So since my vehicle is out of warranty lexus proposed that they will be able to cover the cost of the part but not the labor. My question to you since you did this work already how complicated is it to do it by myself? please let me know. thanks
Old 10-03-08, 06:50 PM
mandyfig
mandyfig's Avatar
Do a search and I actually posted all that is required, including the part number. The assembly was $50 and it is easy to install and it will take care of the problem. You need to add a quart of the Toyota Long Life Tranny fluid TIV.
Good luck.
Old 10-03-08, 06:51 PM
mandyfig
mandyfig's Avatar
Ok, I might have not done the pics, I will search my files and post.
Old 10-03-08, 06:54 PM
mandyfig
mandyfig's Avatar
Here's the part you need to replace. 1st you have to remove the front dam panel, do a search on Air Dam mesh.
Attached Thumbnails Thumping noise when decelerating to 30km/h-picture-002.jpg
Old 10-03-08, 06:55 PM
mandyfig
mandyfig's Avatar
Here's the old and new part. The bottom one is the new version. Replace and refill the fluid.
Attached Thumbnails Thumping noise when decelerating to 30km/h-picture-004.jpg
Old 10-03-08, 06:58 PM
mandyfig
mandyfig's Avatar
Here's the mess while doing the replacement.
Attached Thumbnails Thumping noise when decelerating to 30km/h-picture-003.jpg
Old 10-04-08, 04:38 AM
biff44
biff44's Avatar
the before and after pix look identical to me. What is the difference between the two pipes? Bigger diameter, less restriction, or is it just those two washers?
Old 10-04-08, 03:27 PM
mandyfig
mandyfig's Avatar
They installed a damper...the washer, isolator....this apparently is the cause of the thumping. They isolated the cooler. The old one was bolted directly to the chassis. Best that I can tell. After I installed this, the thumping was gone. Of course, your car would have been one of the earlier ones made, because this TSB was way back old.
Old 10-06-08, 03:00 PM
lebahawk
lebahawk's Avatar
Good luck.
Thanks for the information, since its not that hard i will do this myself rather than paying the dealership a $300 for the labor. Lexus is not willing to cover the cost of the part if the dealer will not install it. So I will probably pay for it myself and do it on my own it will still be cheaper. Thanks for sharing the pictures and the information. My vehicle is an 04 it was assembled in Japan bcz its a JTJ
Old 10-11-08, 07:44 AM
biff44
biff44's Avatar
So, if you are out of warranty, all you have to do is go to the hardware store, buy 2 rubber washers, and install them between the two steel brackets on the pipes and your chassis? I see.
Old 10-11-08, 07:56 AM
mandyfig
mandyfig's Avatar
Will work as you described it....
Old 11-07-12, 04:15 PM
mandyfig
mandyfig's Avatar
Somebody PM'd me about this...time to put it up....
Old 12-04-12, 07:32 AM
Woob
Woob's Avatar
TSB is #TC002-04
Searched and found 2 different part numbers for the assembly:
------- 1 ---- 32907-40831---Tube S/A oil coo --------2 ----- 90119-06942---bolt W/Washer
And 32907-48030, guessing the 40831 is the proper part. Has anyone clamped the 4 tubes before unbolting the oil cooler assembly?
Will need to do this DIY for January, the thumping is pretty darn annoying.
Old 07-26-13, 06:47 AM
mandyfig
mandyfig's Avatar
For those of you having the tranny "thump" on coasting down to 30-20 MPH, here's the DIY on replacing the cooler lines. I did this and it was gone, followed the TSB.
Enjoy.
Old 08-25-13, 09:00 AM
Woob
Woob's Avatar
Enjoy.
Any other info mandy? Where did you order the part? Having a hard time trying to specifically figure which to order. From what I can tell, clamp hoses, undo part, rebolt. May do this on the next flush.
Quick Reply: Thumping noise when decelerating to 30km/h
