I just averaged 69.9 MPG over 11 miles
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
Many Club Lexus users read my article on MyRide about the misconception of 91-octane gas. You actually get more miles per tank on cars that are designed (recommend or require) premium gas. Well I've now done something I thought wasn't possible. I just averaged 69.9 MPG over 11 miles in my 2007 Lexus RX350 AWD (loaded down with all the OEM & dealer options, include the full tow package, hitch and more so it weighs a lot!) with 2 adults in the SUV and about another 30-lbs of misc gear. I also did this with an average speed of 40 MPH - right in the sweet spot I've found for the RX350.
The conditions were not optimal, but I did my best to get the most MPG out of my Lexus, just to see what could be done. I ended up in a lot of stop and go traffic and had to come to a complete stop far too many times (I shut off the car as often as I could, but too many times the stops where to short). I also had to turn on the AC occasionally after the first 11 miles. I shot video along the way and took a lot of photos. With all the conditions I was in I was able to travel almost 38 miles on a single gallon.
I'll be posting my full story soon, along with many photos and videos. I could have done better with no traffic, and there are a number of tricks I used to get the high MPG, some everyone can do everyday, some everyone can do when the conditions are right, some you can do and others won't like if you're on a busy freeway, and some most can't do. My goal was just to see what I could personally do - I've read the stories of people getting amazing MPGs and thought I'd try.
I think this is a great example to start a conversation on what tricks others use to get more MPG, and what is the max MPG you've gotten? I wanted to test 10 miles (it's easy to fill up and get high MPG in a short distance) as well as how far could I go before the miles traveled and the average MPG are equal (distance on 1 gallon).
See my photo and a bit more info at http://community.myride.com/kickapps...8867/3898.html
I look forward to seeing others recommendations and tips. I'm going to try and do this again with a Hybrid, like the GS-H and see what I can accomplish.
Last edited by jamesfabin; 08-17-08 at 04:31 PM. Reason: Added word "almost" to before 38 miles on a single gallon.
I just put up one of my videos from my test - you'll see me doing a decent speed on the freeway and hitting 37 miles traveled with an average of 37.3 MPG. The higher speed (above 40 MPH) and the AC really dropped my average fuel economy, but it's still over double what I usually get. You can see the video at http://community.myride.com/kickapps...8257/3898.html
I'd like to see what others can get out of their RXs!
How many miles did you go? 10?
Are you using the car's computer to make the calculation or are you filling it after driving? The reason I ask is that the first few miles of calculation carry the highest variability and may skew your results.
I applaud the efforts though. Looks like you're a future hypermiler!
Note that all mpg numbers were calculated.
It was too much effort to drive like this every time and the conditions where perfect at the start and near the end (even though I was running 65 MPH or faster often). I'd like to hear what others have been able to get from an RX350 or other heavy vehicle.
Yeah Clarkson took an R8 diesel to the limit. I think it was something like 500 miles on a tank.
Like I said earlier though, your results might be off just because it's the first bit of mileage that the computer is calculating. I can hit 70mpg in my Mini Cooper after filling up, hitting the highway and drafting a semi. But after about 5 miles I have to hit the gas to go up a hill and I'm back to normal.
I short shifted the Mini last week and ended up with 37mpg. I usually get 34.
Statistically speaking you don't have quite enough datapoints to make a call on it yet. Try getting a couple tanks worth of high mpg and then you'll have something.
There are some good hypermiler sites to read. Most involve cutting the engine at stop lights, no idling, and drafting other vehicles. Should be easy to find some good tips.
Was your test a closed loop test? (start and end point being the same ... this way gravity help and retard as well as wind (assuming it stays the same velocity) )
Salim
Salim
Congratulations on that figure. How about the rest of the tankful? In my world, short distance measurements of fuel economy are not real. For instance, I can go to the top of Pikes Peak and show a 15 mile economy of 99 mpg (obviously tongue firmly planted in cheek) on the trip down. A single, short trip with an exagerated figure doesn't tell the whole picture. In addition, I only use actual measurements as real world - that is, miles driven divided by gallons. The rest is a computerized estimate, imo.
As a side note, my wife drove from Pittsburgh to Buffalo at the beginning of this summer, a trip in the vicinity of 200 miles. She set the cruise at a steady 60 mph, didn't stop and then added fuel to the tank. Real world figure of 30.X mpg (don't remember the decimal point). On the way back at 65 mph she got a real 28.6 mpg. This was on the interstate and involved a long enough distance to get real numbers.
Gary
Gary
My test was just on the regular highway. I felt very much like Clarkson - doing everything I could to maximize the MPG. Over the 11 miles I was able to draft behind a big rig most of the way. It was running slower which helped - for me the Lexus gets its max fuel economy at around 39 to 40 MPH. I did have to slow down and stop a couple times for traffic - and I shut off the engine whenever possible stopping. I also was as gentle as possible on the gas, except for 1 time when I nearly missed my exit and had to cut over and speed up quickly. The rest of my 38 mile trip I hit a lot more traffic and came to a stop several times on the freeway, plus I had to use my AC (the temp was 91-95 degrees as I drove across the desert). But I was happy to get 37.3 miles per gallon over a run in traffic of over 37 miles.
If my vehicle had cylinder deactivation and was a hybrid, I could have done much better.
James
James
Well I applaud your efforts, but in TX that is not possible to shut off your car and turn the a/c occasionally. Adding premium fuel to have to shut down the car up and down promotes more wear and tear than if I just add regular gas and not worry about it in my opinion.
