Driver seat click noise
#31
would be interesting to slide a 0.005 or 0.010 inch piece of metal , (from hardware store) or maybe even paper, under the seat track , and retighten the holddown bolts, to see if that changes the noise at all.
or loosen holddown bolts a 1/2 turn or so to see if that is any effect.
maybe unrelated -I once owned a 67 VW square back that had a click where the lower edge of the dash was welded to the side of the car, fix was to bend it slightly with vice grips, problem went away. maybe caused by not enought weld length at that point.
odd some lexus dealers are ignoring it.
#32
Long time for this thread
I fixed it myself,,,took the seat out,,put some grease,just tightened some bolts there,just a smidge each one,I think they balanced the movement and how far the seat will move on the track,,put back and tightened again and never heard it again
#33
This is a great thread, has anybody performed this DIY? If so, any pictures? Need some advice help/direction would be most appreciated. The Avatar from the Post , I cannot make it out the exact location he is talking about! I have sent hi a PM but not sure if he will receive this request for more info!
Thanks
Bob
Thanks
Bob
#34
but also I have had this issue with every Toyota/Lexus vehicle I have owned
08FJ CRUISER
10 Camry
12 Camry
13 Venza
and now 17 RX350 Fsport
had a BMW in between never had an issue
always told by the stealership that they couldn’t replicate the issue
