2004 RX330 Amp Went Out
The amp on my RX330 no longer works. Do you guys have any replacement suggestions? Should I look for an OEM amp or should I go after market?
I really just want to swap out the old one with something new.
I'm new here, so sorry if this has already been posted.
I have lost my audio in my '04 RX and was wondering what your problem presented when your amp died? I seem to be the only one who has had their complete system go blank without warning. I have the base system nothing special like nav. . I apologize if I am intruding here but I am desperate for some answers. I have checked all of the fuses ( 1 under hood and one under dash) and they test ok. If you have any idea please letme know. Thanks
I believe you will need at least an 8 channel amp, at this point if your keeping the stock radio, I'd just get another stock amp as you may have to add a x-over as well as I'm not sure if this system uses a passive cross over or active within the amp. I myself have used an aftermarket amp with the stock speakers, but I also used an aftermarket head unit. Of course, I no longer have this car so I can't go into any specific details, but that is just some of the things I remember when doing my system.
Must be related to 07 RX330 in Illinois! I live in the West Chicago Burbs and mine is doing the same. Only speaker output I have left is Drivers front floor. I guess the amp is located behind the right rear passenger seat. I haven't got mine out yet ........must be a short because when the cars cold all speakers work for a brief while. Any updates out there??
All of you guys may want to hit up your local stereo shop and see if anyone in your area fixes amps.
It's not very loud but I plan on tearing out the old amp and replacing it with something new.
If it is truly the amp that died, ebay has used ones for under $130.00. Simple and easy, but not total replacement to something newer and better.
https://www.ebay.com/itm/2004-2006-L...MAAOSw8xVfocTC
