NAV and Bluetooth bypass DIY
#31
Just to clarify, has this worked on a vehicle equipped with ML ?
I have a 2008 RX400h w/ ML but it is UK spec, is this likely to make a difference ?
Many thanks for any insight
#33
Would anyone be kind enough to tell me what specific function the wires being cut in the first part of the guide are supposed to serve ? Would like to replicate the process on a UK spec vehicle but there is a chance the unit may be configured differently, so could someone enlighten me how best to identify the appropriate wires ? Would a car audio specialist be able to do this quite easily ?
Many thanks
Many thanks
#34
hello, i have a 04 rx330. any ideas on how to do same (nav. hack during motion)? i have searched many websites with little results. mainily 350's and 470's. thanks.
#35
You should be able to do the "volume" screen secret override. See other posts in this forum for details. I wish Lexus would have kept that one in...
#36
with this hack you can actually use your blue tooth in the car. for example prior to making these changes, i could not dial out from the touch screen, i had to dial the number from the phone it self. Now i can dial the numbers while in motion. I have found out that this is kind of dangerous so now i let the passenger dial the number instead of me.
as far as the ipod goes, prior to making these changes i could not do much other than song up or down. Now i can select folder, playlist and browse thru songs and select the one i like. Again i let my passenger do this most of the times so i can concentrate on the driving.
#37
If anyone with ML system has access to full wiring diagram and wants to share it with me i will look at it again and see if i can come up with any thing
#41
I've 04 RX with rear DVD. If I do the bluebooth wire hack, would that also enable the display of dvd video on the front screen while in motion (by pushing the disc button)? Thanks.
#45
04 rx 330, do you know what wires to cut, and between what wires to install the switch to watch dvd on front display when driving(I have a rear entertainment system on the ceiling) I'll apreciate any help
