RX350 Suspension
hei, im looking to lower my rx350. i wonder can anyone give me some advice or suggestion on whats sort of coilovers to use so i can still get soem comfort ride. i do know that it will not be as comfy as the orginal. thank you
No coilovers available for rx330/350 over here.
You can get lowering springs though. Couple quality brands are H&R and Eibach.
By installing those on stock shocks you will lose some ride comfort, so if that is a big concern then get some after market shocks like for ex. kyb gr-2 and ride quality will probably be better than stock.
TEIN was supposed to come out with one for the 04+ RX330/harrier, but I don't know if they ever followed though with it. Personally, if you can afford it I'd go with air suspension. Believe it or not, the Airrunner suspension actually rides and handles very well for air. Not floaty at all. I know people with IS350s with Airrunner and it handles a lot better than you'd think.
if your ballar enough
http://www.airrunnersystems.com/cont...tions/lexus#rx
another option that would be half the cost of AR is UAS(universal air suspension)
you can put together a kit and must buy aftermarket adjustable struts.
theres many people rolling around in these and have no problems(though comfort is not as good as AR), some cars differ. the main thing on all airride is to inspect for leaks in fittings caused by hot/cold climate changes.
i think im giving out too much information![Batman](https://www.clublexus.com/forums/images/smilies/batman.gif)
so who wants to step up?
i have checked the website. price is in my budget. however im thinking of the reliabilty and lifetime for the suspension. i assume the compresser and tank will be need to be in the trunk?
For an RX, you can also run a couple of smaller compressors and mount them under the car on the frame rails. The only real reason for a large capacity tank is if you plan on raising and lowering the ride height often. Stock Lexus LS with air suspension don't have an air tank at all.
can u raise and lower on the ls suspnsion? im not planing raise and lower it that often or i think i will stick with the height once im happy with. is there anyway i can modify and fit the ls suspension to my rx?
Don't bother converting an LS air system for your car. The Lexus airbags use the same type as the Air Runner, plus cost of the stock parts are easily as expensive or more than the Air Runner. Might as well just buy the Air Runner kit that comes with everything.
808mcv20l
01-28-16 12:06 PM
