cluster of indicator lights keep lighting up when driving
Every so often when I glance down at the instrument panel on the right side, all of the indicatoir lights will be on: ABS, BRAKE,VCS,TRAC OFF, SLIP, WASHER FLUID, AND LOW TIRE PRESSURE. If I turn off the engine and restart it, they all appear for a few seconds and then go off as they normally do. They may not repeat this for hours or even days, and I forget about it. Then it will happen again. This started a few months ago, but seems to be happening more frequently lately. Any ideas?
Strange
This exact same scenario has just started to happen about four times (last three weeks) in my spouse's 07 RX350 AWD with 45,000 miles. It is very random and erratic.
The car is scheduled for service this Monday; will keep you posted as to what the dealership does.
As mentioned earlier, we dropped of the car today for service. The dealer replaced the brake light switch. When we mentioned the problem, the SA knew exactly what we were talking about..... it seemed that he has seen quite a few of vehicles with this issue.
The service order lists " T1-72 & T2-71". Does this denote TSIB?
It hasn't reocurred for a couple of days, but I have an appointment tomorrow to have it checked out. Thx CEO ENGR for your info. I'll update Monday.
Re:
I have experienced the same issue with my 2004 RX330 AWD and I took it in to the dealership and they found out to be a "Brake Switch" located near the brake pedal area. The cost to have that replaced was $150 I hope this will help you with your diagnostics.
It was the same switch as CEO ENGR and lebahawk...the "brake light switch" assy. Thx for your help guys. But as usual, the dealer ripped me.... $221 + tax!
What about the center display? Does that dim out when all the warning lights come on?
Salim
Salim
Recently I was running on battery power only [no alternator]. As the 12v from battery started to fall over time, I got to a point when all the waning lights came on [all sensors were putting out voltage in warning zone], but then the battery voltage drooped so low as to turn off the center display.
Salim
Salim
Re:
In my case it happened twice like two days appart happened during night time and the second time was during day light. Did not notice any changes in the center console lights.
I have the same problem with this lights my question is to any of you guys . After the brake light switch was replaced what happen the problem persist or was resolved
