Loud engine sound from rx330 is this normal?
Hi there new member and a first time owner of lexus. Just bought the rx330 2004 model used with 47k miles in it we are very happy with the purchased it runs great and smoothly only thing that we noticed is the engine sounds while driving is kind of loud it is like there is a chopper or plane flyng just above us, while maybe that is exxagerating but it sounds like there is a chopper or plane in a distance is this normal with lexus rx330?
Thanks,
Peter
Thanks,
Peter
I don't think you should be hearing any type of loud noise. Can you provide additional info? What speed were you driving at? Didn't you test drive the vehicle before you bought it?
just normal speed for city limits/highway limit I can hear it. It is more like an engine running sounds (continously) it is not like a metal to metal sound it's like humming sound but it is noticeable and even my wife noticed it too, the thing is we test drove MDX and RX330 and we both heard it in both vehicles, I research a little and sounds like it is normal sound of the engine it just that its just weird like a roaring sounds. I will search for more and thank you for your reply.
I also recently bought a 2004 RX 330. It is very quiet. I suspect you have some sort of problem. I've had noise in other vehicles from the water pump and other devices under the hood other than the actual engine. Does the sound vary with the engine speed or is it fairly constant? I'd have a mechanic look at it or you could at least try to see where it's coming from by checking under the hood. Also, do you hear it as much with all the windows and sunroof closed?
maybe are the tires ((47k = second set of tires)) some people buy expensive cars but they are cheap when it comes to wear and tear... take the brand and model search in tire rack the tire specs and rating..
only when I am driving I could hear the sounds, but when I am stop I don't hear anything
only when I press the gas pedal it would be quiet for about a minute or two and then you can hear the noise again I am sure it is coming from the engine I read about this in other forum site that owners can hear it too that it is coming from under the hood, I will definitely have it check.
I checked the tires and they are brand new, They are made by Michellin and I am sure it is brand new it say something about LX4 printed on the side and it was late last night when I check back with this thread so I will check it tonight I think it is just the Tire itself, hopefully though.
I have a 2004 RX330 with 170,000. The engine has always sounded a little loud when driving. Recently the sound has gotten louder when I get up to about 40mph or higher. It does sound like I am in a motor boat or something. When I look under the hood it sounds a little different than it did. What could this be.
MattRX (06-05-22)
