Tranny and Rear Differential fluid changes
Greetings!
I have read in several posts regarding changing:
-Transmission Fluid (and filter)
- Differential Fluid
- and Transfer Case (?) fluid
Can someone fill me in as to the recommended what needs/doesn't need to be changed on a 2004 RX 330?
According to the maintenance schedule, it is not recommended unless you are driving in "severe" conditions. I have changed the trany fluid on every car I have owned and the rear diff on my Honda. This maintenance free approach seems very strange.
Also, does this model have a pan to drop, or drain plug?
thanks.
thanks.
When we had our '04 I changed all the fluids at around 50K. Had the tranny flushed & I did all the other fluids. Put in 100% synthetic lubes at that time.
To me, severe conditions are any conditions that the vehicle is driving in. Not severe is if it is storage.
I posted a reply regarding the transmission fluid change several months ago. I also mentioned that Lexus doesn't recommend a fluid change unless you are doing off road, towing or other severe conditions. The replies that were posted, showed that the owners change at 15K or 30K or whatever, without any justification as to why. I really wish that someone who actually works for Lexus would explain the reasoning for the "no fluid change" for normal driving. In spite of what Lexus says, I plan to change the transmission fluid on my 2007 when it turns 50K.
The newer RX350's, for example, come with the newer WS transmission fluid instead of Type-IV which came in my '04 RX330. Not sure exactly when the change was made and if all RX350 models use WS. If your RX came with WS transmission fluid it probably will never need changed from all indications I have seen.
Most of us who are changing their fluids early have Type IV transmission fluid which is not a full synthetic like WS.
Drain and fill, we are not changing it. However it is mentioned in the manual as to the volume of fluid required of you were to drain the transmission. I drain and fill every 15K miles, means every other oil change. And I use full synthetic on the engine oil and Type IV on the tranny fluid.
Hate to bring this thread back but I have been thinking it's time to do the rear diff. at 120K. Dunno it it's ever been done. any ideas what else to change?? If I should worry about the rear diff?
So yes, do it. And your spark plugs, oil and filter, brake fluid, transmission fluid, engine + cabin filter, power steering fluid, coolant (if it hasn't been done, it was due at 100k), with Toyota pink, t-belt, wiper blades, rotate the tires, and check everything.
The local dealer here recommends rear differential and transfer case fluid every 15k.
- Engine oil filter I do
- trans fluid drain and fill done myself
- Cabin filter done
- T-belt done already a while ago
- blades
- tires come on now..
- Spark plugs I hate having to do this but ok. freaken $650! What a bad day of engineering.
Sigh ok on the the dealership..
EVERY 15K!?!? Good lord!
- Cabin filter done
- blades
- Cabin filter done
- blades
Remember the days of the Chevy Monza V6 where you had to jack up the engine to be able to change one of the plugs nearest the firewall.
I bought SAE 80W-90 gear oil. Dong Thr rear diff. today. Is this the righ oil? Calling the dealer but hope they don't give me the rn around. I don't have the service manual.
PS: Lexus dealer confirmed.
I use the AMSOIL site as a reference as to the required lubricants and capacities.
