2004 Rear Tail Light Replacement
Anyone done this? Searched forums and goolge'd, but doesn't seem to be simple, step-by-step instructions. Thanks.....https://www.clublexus.com/forums/ima...es/biggrin.gif
There are 2 tails. One mounted on the body and the other on the lift gate. The one on the body corner is easy, pop the cover inside and unbolt, tricky but doable. Pull out and replace. The ones on the tailgate, you will have to take off the panel, but should be straighforward, too.
calvin2376
09-28-11 12:40 PM
