help stop indicator light when oil change myself
any one can help me to stop the indicator light blinking after doing oil change myself on RX 330 and ES 330?
thank you
thank you
Make sure the odometer is set to total miles not trip. With the key in the off position, push in and hold the odometer reset button (ODO). Turn the key to the on position without starting the car. Continue to hold in the odometer reset button until the maintenance required light goes off (about 20 seconds).
kennylexsc
12-09-08 10:17 AM
durnil
11-16-04 10:48 AM
