Help - No DRL or High Beams
Have a 2004 RX330. While driving to work this morning, I turn on the high beams. High beam turned on momentarily, and then went out. High beam indicator was on. Further check revealed that the DRLs are out. I will check blubs and fuses tonight, but would appreciate any advice you can give me.
Thanks,
Art
Thanks,
Art
My understanding is that the left and right high beam bulbs, form a series circuit in DRL position. This makes them run at half voltage and the intensity of light is reduced.
Check fuses, then each bulb.
Salim
Salim
^^ It does not seem like a series circuit then.
Salim
Salim
You know what, I can't be sure anymore. I remember I wanted to disable my DRL and was playing with removing fuses and removing one bulb and neither worked out for me. My info is too and based off memory and can't be reliable anymore
I don't have the car anymore so I can't verify. I used to remember everything I did to my cars but I guess I'm getting old
First off, thanks to all that replied.
This is one of those problems were you cannot ignore the obvious. Fuses were good and voltage was present. Turns out that both bulbs blew. Unusual to say the least, but I'm guessing that when the first bulb blew it may have caused a slight surge that blew the other.
Thanks Again,
Art
Thanks Again,
Art
Returd
Performance & Maintenance
11-22-18 05:47 PM
