rear Brake Rotors Help Please
Hi gys, I want to remove the rear rotors, i got to the point of removing the rubber plug and try to release the emergency brake ,wheel was turning but did not know how to remobe the rotor,help will be appreciated
FYI:
As long as the drum portion can spin, and the grove has not been cut (happens when you shoes cut a groove), all you need to do is gently tap with a rubber mallet and pull it off evenly.
If you turn the knurl/star nut, make sure you are not making the shoes come up.
[I doubt it but just make sure your aux brake is released]
Salim
Salim
gmacrae
02-16-12 02:16 PM
chiseenlow
08-16-06 08:59 PM
