Toyo Proxes STII 255/50/18
No it isn't a TRD kit, it I can't remember the name but it is a factory body kit from another company. It fits perfectly. It was a cinch to put on too. Took me two days cause I only had about 2 hours each day to install when I did put it on.
Very nice write-up indeed. Definitely worth considering for those that need new tires anyways. The slightly wider thread helps a bit.
Are you lowered at all? If not, L-tuned springs would fit nicely with your car.
Can't lower it, I have the factory air suspension. If I were keeping it longer as a play car I would consider finding ways to lower it or add a air ride suspension that would allow me to use some of the factory equipment. That would be fun.
