2007 RX350 AWD maintenance question on transmission
So I finally hit 30k and need to change the transmission fluid. Can I get the ATF from a Toyota Dealership? If so what type of ATF do I need? How many bottles of this stuff will I need to use? Does the FWD transmission fluid differ from the AWD transmission fluid or are they the same?
Thanks!
Thanks!
Nvm I think I answered my own question after doing a bit of searching. WS ATF if I am correct? Also is there any other fluids I should be worried about changing?
Your manual has the list. oil/filter, check/bleed brakes, air filters, rotate tires. Consider the front/rear differentials if driven hard.
