VCS, ABS, Brake light
Old 02-01-09, 01:32 PM
ciba401k
ciba401k's Avatar
Low brake oil...... I am willing to buy this argument........ It has only happened in the cold temperatures so far...... so the expansion and shrinking of brake oil is a possibility.
If it were the o2 sensor, shouldn't the check engine light come on ????? Which o2 sensor are U thinking?
Let me go check the brake oil while U reply
Old 02-01-09, 02:27 PM
Bear60
Bear60's Avatar
Yep the "Check Engine" light (symbol of an engine) would come on if the computer sensed a problem with the oxygen sensor and there would also be a diagnostic trouble code(DTC) stored so the dealer would have found that during their inspection. They may not have noticed if the brake fluid is slightly down. It has been my experience that the warning light will come on long before the brake fluid level reaches the low mark. As brake pads wear normally, the caliper piston has to move out of the bore to compensate. This means that the brake fluid level will drop.
Old 02-01-09, 03:33 PM
ciba401k
ciba401k's Avatar
Brake fluid level was fine.........Any other ideas
Old 02-01-09, 03:51 PM
JorgeGVB
JorgeGVB's Avatar
Originally Posted by Bear60
If the brake fluid level is just slightly low, it can cause these warning lights to come on. When cold the brake fluid shrinks and the levels drops. Then when it warms a little the level will be OK and not show a fault. Add some DOT 3 brake fluid from a new container and the warning lights should stay off. Do not add above the "MAX" level to allow room for expansion.
In my case, the light has come on after driving awhile and the car was warmed up. I will check the brake fluid anyway though.
Old 02-01-09, 04:31 PM
ciba401k
ciba401k's Avatar
Even the lexus dealership is clueless............since your car is also warranty, can you take it to the dealer and lets see if there is a better mechanic there, maybe a smarter one.
Old 02-01-09, 05:30 PM
GQD_GS4
GQD_GS4's Avatar
its most likely the brake pedal switch...do a search, it's been posted about before:
https://www.clublexus.com/forums/rx3...driving-2.html
Old 02-01-09, 06:15 PM
ciba401k
ciba401k's Avatar
This looks like the likely cause... Thanks GQD
asdflkjasl
GX - 1st Gen (2003-2009)
09-02-18 07:16 PM
catbud
12-06-17 09:20 AM
Socal2
ES - 5th Gen (2007-2012)
12-05-17 04:59 AM
sonny1948
08-16-09 06:34 PM
robbieromo
RX - 1st Gen (1999-2003)
09-04-04 05:17 AM
Quick Reply: VCS, ABS, Brake light
