5,000 mile oil change
I have 2,200 miles on my 09RX, the car is about 4months old. i probably wont hit 5,000 miles at this rate for another few months, should i wait until i have 5,000 miles or bring it in sooner? thanks in advance.
I'd wait till you get to 5000 miles or close to it. If it was taking you this long because you are taking many very short trips that the engine never gets to burn off the contaminants in the oil than you should switch to a 3000 mile schedule.
Jeff
Jeff
Don't change the factory fill early because it has higher than normal amount of moly during engine break in.
This is one of the many cases that changing the oil too soon increase engine wear.
There are so many different theories and opinions about oil changes that it will make your head spin trying to decide what, or who is rite. What I do is just follow the manufacturers instructions in the manual. Change the oil at 5000 miles or 6 months, which ever comes first. Why risk giving Lexus and easy out if a warranty situation come up with your engine. They can say the problem is that you didn't follow the service requirements. Oil is cheap insurance.
i get that for future oil changes, but I'm concerned about the first oil change my car only has 2,200miles. I've had the car for about 5 months. i hear the original oil has a special blend of something, so should i keep it in the car for a full 5k even if it takes 7-8 months. thanks
I think if break-in oil was a concern to Lexus they would go far out of their way to insist we wait until the full 5000 mile are logged. They specifically say 6 months or 5000 miles, which ever comes first. However, if in doubt, call your nearest dealer and ask for their opinion.
I, like you do not put on a lot of miles on my 2008 RX. I finally went in when I had around 4400 miles on it. My 10,000 mile check up was due Dec. 17, 2008. I have around 7600 miles on it. My Lexus dealer said just wait until I had close to 10K to bring it in. Thats what I'm going to do.
UOA is not a subjective opinion, it is objective, scientific proof from independent users from indepedent labs, reporting spectro-analysis of the oil contain.
Previously I linked to a UOA to a 4 cylinder sedan, here is a Toyota V8 truck. Different car, different owner, same factory fill, similiar report. Tundra Thread
Well, call me the contrarian. I would NOT wait beyond six months, regardless of mileage. Call it cheap engine insurance if you will. Engines produce byproducts that can make acid if the oil is allowed to sit in the oil pan, with any residual moisture. As an example, I have a classic Corvette that on a bad year might get driven 1000 miles. The oil does get changed at the end of the fall, regardless of the mileage.
Every oil has acid neutralization additives, UOA will show Total Base Number if one pays for it at the lab (or go to a lab that include it for standard testing). It is when the additives are depleted (TBN < 1) that oil needs to be changed.
Here is a Toyota Yaris 1100 miles on factory fill, TBN is still 3.1 and no need to drain. Notice Moly is also high.
Changing oil sooner than needed is throwing $ out of the window. Even recycled, 3.5 quarts out of 5 quarts are not converted into recycled oil. In another word, most used oil get dumped into wasteland, ocean or burned in the air. Something to think about in today's environmental awareness age.
Of course, no every one test oil or test it every time. However, if Toyota factory fill has a special brew with extra moly, why not use it when there are clearly enough acid neutralization additive left for an engine that is gently driven for 2200 miles?
Those good old practice or rule of thumb needs to change. Heck, we are discussing cars on the Internet, 20 years ago folks will laugh at us, "you got your information from someone whom you never see or talk to?"
