Is the maintenance expensive???
Im still trying to make ky mind up on what i want...i just have one more ?. Is the maitnece expensive on the RX330? Can you guys give me some averages prices on wht it cost?
depends if you go to lexus for the service.
if you do:
oil changes will run you around $150
and then every 15K miles, you will get a major service, which will run about $300
both of these cover quick oil changes and refilling fluids, tire pressure, making sure everything is okay. kind of costly, and then you have to factor in brake pads, tires, etc etc.
and so if you change the oil yourself, it should be less than $50
if you do:
Watch out for the upsell of service. Consult the forum . .the only one that I know is a general opinion to drain an fill transmission fluid more frequently than the min. specified by manufacturer. .. Oh .. that also depends on the model you are driving.
You can take your synthetic oil to the dealer too.
Salim
Salim
The cost depends on the dealership. I've found an oil and filter change to run $45 at Woodfield Lexus, for example. http://www.woodfieldlexusads.com/Ser...ecials_Ad.html
You can also print out the coupons and ask if your local Lexus dealer will match the price. Mine does.
You can choose to have your routine maintenance done by a Toyota dealer for about 20% less.
If you have to ask how much the maintenance on a Lexus RX330 or RX350 is, then you cannot afford it. These wagons don't break down often, but when they do it's usually double what you would pay at one of the other luxury brands. Count on a drivetrain issue between 60,000 and 80,000 miles that will cost between $2,000 and $5,000. And most people I know have an electronics or control system issue that can cost $1,000.
Powertrain Warranty
The Powertrain Warranty is for 72 months or 70,000 miles, whichever occurs first. Except for the situations listed on the Basic Warranty page, this warranty covers repairs needed to fix defects in materials or workmanship of any component listed below:
Engine
Cylinder block and head and all internal parts, timing belt and cover, flywheel, oil pan, water pump, fuel pump, engine mounts, engine control computer, seals and gaskets
Transmission and Transaxle
Case and all internal parts, torque converter, clutch cover, mounts, engine control computer, seals and gaskets
Front-Wheel-Drive System
Driveshaft, axle, hub, bearings, seals and gaskets
Rear-Wheel Drive System
Differential carrier assembly, driveshaft, axle carrier, axle case, axle bearing, axle shaft, seals and gaskets
Engine
http://www.lexus.com/models/IS/warranty/index.html
^^ ... that makes/qualifies me as your friend. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Salim
Salim
As has been suggested, if you don't do any of your own maintenance, then it can be expensive as compared to "normal" cars. Probably in line with other luxury brands, although I have no experience yet. My BMW is in warranty but I will wait and see how it costs to maintain it.
My 2005 has been flawless with only one complaint on moisture in one headlight and it was replaced.
My dealer has a computer center, nail salon, coffee bar, free washes (just call ahead of time) etc, etc. You have to pay for that somehow.
I do my own routine maintenance so the cost is only in materials.
I don't know where the person who pays $150 for an oil change goes but in Minneapolis it is $47 which includes care wash (hand dried) and check and fill fluid levels
