FM Transmitter and FM Radio? or MP3 ?
I have a Zune and I got a Zune FM transmitter, but it kind of sucks because I am getting bad reception on the Rx does anyone have any ideas?
I also have conflicting information some say the FM antenna is rear glass mounted while others are saying it the antenna on the roof. I have 30 days to return the Zune and its car transmitter.
Does anyone have a MP3 player and transimtter that works well with the Lexus RX 2004 no nav?
I considered an iPod adapter, but my dealer wants $500 for it. I think that is excessive! And I am afraid to go aftermarket since my CD player gives me an Error 4 once in awhile and I am still trying to get Lexus to replace it under warranty.
My last option is an after market radio with GPS builtin, but going to bestbuy.com and sorting it by car, non fit the RX.
Basically the sound quality is similar to FM.
The only disadvantage would be the cassette and the wire sticking out into your Zune.
the cassette adapter is the low tech way to go but if you player is noisy then I'd think about an aftermarket mp3 adapter like vais. There are threads about that and how to install it like https://www.clublexus.com/forums/rx-...-04-07-rx.html
You'll get different opinions on any FM transmitter, zune or otherwise. Hardcore folks tend to think the sound isn't good enough. Others, me included, think it's fine given the RX acoustics, so long as you can get a clear signal. For any of them to work you have to find a space on the FM band where there is no station signal. Strong signals on a nearby frequency also can be a problem. We had enough difficulty keeping a clear signal and drive in a range where stations come in and out that we went for the vais kit. There should be on to fit your 04, if it works with Zune. I don't know if they are ipod only or not. worth a look. vais.com
Have you tried setting to a frequency with little distortion, ie not a frequency with a radio station already broadcasting on? There is an antenna on the back sticking out, which is the radio antenna.
I have a FM transmitter for my iPod and it works well with my radio. Now I just burn my MP3s directly onto a CD (One CD can fit about a hundred songs).
For Zune--> Soundgate adapters were just $12
joetifosi
RX - 1st Gen (1999-2003)
12-26-17 07:22 AM
aftermarket, bad, cd, fm, klub, player, radio, reception, sc400, sienna, sis, toyota, transmiter, transmitter, zune
