DIY: Remove condensation from headlamp (temporary)
Old 03-13-09, 07:59 AM
runningox
runningox's Avatar
How did you keep the headlight without yellow foggy appearance? It is really crystal clear! beautiful!
Old 03-13-09, 09:52 AM
mandyfig
mandyfig's Avatar
Originally Posted by mr2tosc4
They are sealed, but seals get weak over time, water will come in eventually. If the breather hoses are blocked, the trapped water would take a long time evaporating through the seals it managed to seep into. Toyota saw this coming so they put breather hoses at the back of the unit.
Have not seen breather hoses on these head lamps....where is it located> Anybody know?
Old 03-13-09, 10:42 AM
mr2tosc4
mr2tosc4's Avatar
Take it out so we can all see I barely have 1k miles on mine so don't see the need yet
Old 03-13-09, 01:26 PM
mandyfig
mandyfig's Avatar
I only have 37K on my RX330. Except for the condensation, they look good. No hazing, no yellowing.
Old 03-13-09, 01:29 PM
mandyfig
mandyfig's Avatar
If this were an easy DIY, I would have done it. You will have to take down the fender liner and the front bumper cover...to get to the 3rd bolt.
Hence, a long time ago, people were ripping off the head lamps and selling them on ebay, minus the 3rd bolt bracket....it was funny, they tell you where to get the material to repair it...LOL!
Mine is a non-HID. So I did not worry about stolen head lamps.
Old 03-15-09, 09:23 AM
CometVR4
CometVR4's Avatar
I did this on my TL. Buy some clear or black RTV silicon at a parts store. Remove the headlamp from car, remove the HID ballast and all bulbs. Bake headlight in oven for 200 degrees (No need for preheat) for 20 minutes. Remove headlight and the OEM silicon used to keep the headlight sealed will be soft. You want to apply firm pressure all around the headlight and try to get that tight seal again. Hold pressure for about 10 min, after that apply a small bead of silcone around the headlight to fill in the gaps. You won't have anymore problems.
Old 03-15-09, 05:31 PM
mandyfig
mandyfig's Avatar
^^I have read this process from quite a few boards, yes it works.
Old 03-15-09, 05:57 PM
lexusscturbo
lexusscturbo's Avatar
Also for resealing..Fill your tub with water..Drop the light in..look for bubbles..and seal.
Old 03-18-09, 09:55 AM
mandyfig
mandyfig's Avatar
I will tear this apart this weekend. I bought my clear RTV seal and I will get the HL out and will add air pressure while submerged on water. I should see a leak. Then I will seal, and do another leak test. I will do a detailed DIY on this repair.
I am tired of looking at my HL all wet inside!
The HL are sealed type, no breathers. Once there is a leak, condensation will ocur.
Old 03-19-09, 07:49 PM
mr2tosc4
mr2tosc4's Avatar
Since you're still under warranty, why not just have the dealer replace them?
Old 03-20-09, 05:40 AM
mandyfig
mandyfig's Avatar
Nope, out of the 4 year warranty. I do have extended warranty but this head lamp issue is not covered. I missed it by 2 months. The condensation appeared a bit late.
Old 03-20-09, 05:41 AM
mandyfig
mandyfig's Avatar
I am all geared up and will take pictures for those of you you hopefully will not find the reason to do this, but in case you have to, then this will be good reference.
Old 03-20-09, 05:42 AM
mandyfig
mandyfig's Avatar
200 Degree F right, not Centigrade.
Old 03-20-09, 04:44 PM
mandyfig
mandyfig's Avatar
Finally did the repair! See my new post for the DIY!
tightlinez
GX - 1st Gen (2004-2009)
83
01-15-24 02:26 PM
TAMR_GUS98
09-05-18 04:48 PM
kee0419
12-30-14 11:21 PM
ManXP
05-16-13 07:42 AM
bob2200
RX - 1st Gen (1999-2003)
03-19-09 04:18 PM
Quick Reply: DIY: Remove condensation from headlamp (temporary)
