drivers window works; other 3 do not
my car has been sitting since october for the winter; i have been starting it once in a while but not driving it.
i took it out this past weekend and noticed that the drivers window works but the other 3 do not work
could this be a fuse issue? doesnt make sense because the one window does work.
thanks
thanks
Mine did the same thing after the battery was disconnected for a short service procedure. You have to retrain the windows by putting them up and down fully from each individual door.
I think you go down all the way and hold the control down for an additional 3-5 seconds, then up all the way and hold the control up for an additional 3-5 seconds. After doing this they should work from the driver's door again. You may also have to do the same thing to the sunroof or the automatic opening function won't work.
Dave S.
Dave S.
I had exactly the same thing happen to me 04 RX 330. Someone thought I'd need a new driver's side panel ($750 before installation).
I tried the "go to each window and roll it all the way down and up" and then went to the driver's panel. It worked like a charm.
Hope that is all that is wrong with yours, too. I was very relieved!
Needs re-set. Manual gives you directions...it makes sense to read the manual, every now and then.
evren
02-27-06 05:41 PM
