Removing the cross bars, simple DIY
#31
#32
I am not driving the car today. But I will try to get a picture this weekend.
On the plastic rails. I believe these are the Part Numbers.
Part Numbers: LH & RH
75551-48041
75552-48041
75551-48041
75552-48041
#33
Found this in a search. This should be for the 4 small channel pieces.
Originally Posted by thwang99
You need four of these, at $11 or so each:
75595D, RH side
75596D, LH side
They are small rubber pieces that will fill the gap. Hopefully they are the right parts, I just ordered them, should get them in a few days! I'll let you guys know.
75595D, RH side
75596D, LH side
#36
Looking good thanks for the pic. Did you say you ordered the pcs? Whose picture is this?
#37
I'm going to be a contrarian here, but I don't think the removal of the bars adds anything to the esthetics of the vehicle. Rather looks odd without them. But, if that is what you want, go for it.
#38
This my 2007 RX. If you go to any Lexus dealer they can order the plastic rails.
75551-48041
75552-48041
After I put mine on. I sold the whole rack. Made 1 1/2 car payments.
On the racks being better looking with them. I cant believe Lexus put them on to start with. Does anyone every use them?
Of all of the RX's I have seen driving around. I have never seen anything on the top. For myself. I wouldn't attach anything to the roof of a car I paid 45K for.
75551-48041
75552-48041
#39
^^Thanks a lot. One part per side? Total 2 pieces, left and right? How much were they? Thanks again! Great stuff! If ever I do this, I will do a DIY. And wil sell the racks!
#40
Much better look. You are right, who uses them? For the looks...maybe at one time, nowadays...less drag better...more fuel efficient. Green!!!
#41
And it will be 10x easier to clean the roof when you wash the car!!!!
#42
Thanks a ton for the pics.
Did you fill the holes or seal them at all - or did you just put the rubber strip over them?
#43
Yes, There is one per side. You remove all of the old pieces and the long plastic pieces just snap into place.
On the installation. I used a small amount of black silicone sealant on the front and back edge. So it didnt collect water in the corner.
On filling the holes. There are none on the top of the car. I drove it with nothing in place for about a week. Waiting for the pieces to come in.
With no rails and the steps installed. It just takes a couple of seconds to clean the roof.
#44
Couple of tips on removing the rack
The plastic molding just slides off. Foward and aft parts. You need to use 2 common screwdrivers to remove them. The first needs to lift up the skinny end. So it will go over the plastic base piece. With the second screwdriver. Put the tip between the gap. And spread and push the plastic piece from the rack. And it will slide right off. Take care as the plastic molding scratches easily. If it feels really tight. Adjust the screwdriver that is lifting the piece up over the base plastic piece.
Once the 4 moldings are removed. With a 12 MM socket. Remove the 8 each silver bolts. I lifted the entire section off the car. But if you want to take it apart on the car. There are two small 8 mm screws that stop the cross bars from going all the way back. With the two small screws removed. And the aft plastic molding removed. The cross bars will slide all the way off.
#45
My cross bars are off. All I need to remove are the 2 supports. This is getting better each time. How much were the plastic trims? Thanks a lot. DIY coming up.
