*MERGED THREADS*: Headlight Condensation includes DIY instructions (See Post #19)
Old 01-01-13, 03:25 PM
  #136
mandyfig
Forum Moderator
mandyfig's Avatar
Great for you. Took pics?
Old 01-01-13, 05:14 PM
  #137
GadgetmanN
GadgetmanN's Avatar
Well, I have a pic of the before, and I guess I could take one of the after. But all you would see in the after is (if you look real close), the white powder that was freed up during my dis assembly (the white powder was corrosion on the aluminum housing of the ballast). At first it bothered me pretty bad, but now I have come to accept it. The RX is 8 years old, so it will not be perfect, but it looks a whole lot better than condensation! And my new years resolution this year is to not sweat the small stuff so much
Old 02-04-13, 09:19 AM
  #138
mandyfig
Forum Moderator
mandyfig's Avatar
This reminds me of the bug in my rear tails. It does not bother me anymore.
Old 02-09-13, 02:14 PM
  #139
nicholasRX
nicholasRX's Avatar
Default Ballast was severely corroded
Did this repair on my 2004 RX 330 today. Thanks for the walkthrough, things went fairly smoothly. One of the fasteners for the ballast was rusted in and the head snapped off. Other than that smooth sailing! BTW no third bolt on step 5 on the driver side of my '04 RX330.
Thanks mandyfig!
Here are a couple of pictures of the ballast.
Old 02-10-13, 03:17 PM
  #140
mandyfig
Forum Moderator
mandyfig's Avatar
Great photos. Good for you. You are welcome. I hope Lexus-Toyota learned their lesson on this.
Old 02-18-13, 09:53 PM
  #141
djcrx330
djcrx330's Avatar
Followed the instructions in your post on this subject. I have the passenger side headlight assembly out of the vehicle without a problem. Poured an ounce or 2 of water out of the ballast compartment. Have dried it out (mostly) with hair dryer and allowing it to air dry for a day or two. My plan is to carefully lay in a bead of silicone around the entire seam where the black plastic meets the clear plastic. I have read about the existence of vent holes that are part of the assembly. I am assuming that the vent holes are in the black plastic housing. I have not been able to locate anything that appears to be a vent hole. I find nothing that resembles the vent holes described in the postings, i.e. holes with yellow foam in them. I have probed everything that looks like it can be a hole in the black plastic. I have used a tooth pick. Every hole seems to be a dead end. Even though my main mission is to seal the seam in the assembly, I think it must be important to have a "vent" or "breather" on the assembly. Since I am not finding one, should I drill a hole? If you don't recommend this, where is the "vent" or "breather" on my vehicle's headlight assembly? Would like to put the vehicle back together on Thursday. Hope to hear from you before then.
Old 02-19-13, 01:15 AM
  #142
GadgetmanN
GadgetmanN's Avatar
The vents are white plastic "caps" that cover the vent holes with foam plugs in them.
Old 02-19-13, 07:25 AM
  #143
mandyfig
Forum Moderator
mandyfig's Avatar
I would not worry about the vents getting plugged. Seal the leak, I say.
Old 02-19-13, 12:10 PM
  #144
kickin8
2IS/2RX/4RX
kickin8's Avatar
Noticed this last week...
Attached Thumbnails *MERGED THREADS*: Headlight Condensation includes DIY instructions (See Post #19)-20130210_150847.jpg   *MERGED THREADS*: Headlight Condensation includes DIY instructions (See Post #19)-20130210_135255.jpg
Old 02-19-13, 12:18 PM
  #145
djcrx330
djcrx330's Avatar
Default No such "animal" observed
Looked over every inch of the housing looking for white caps or anything at that could be a vent. None seen. I am a new member and not savvy avout how to attach photos, otherwise I would post a photo attached to this message. I will try to attach photos (3 of them). Anyone able to identify the vent holes (breather holes)?
Attached Thumbnails *MERGED THREADS*: Headlight Condensation includes DIY instructions (See Post #19)-photo-1.jpg   *MERGED THREADS*: Headlight Condensation includes DIY instructions (See Post #19)-photo-2.jpg   *MERGED THREADS*: Headlight Condensation includes DIY instructions (See Post #19)-photo-3.jpg
Old 02-19-13, 01:48 PM
  #146
mandyfig
Forum Moderator
mandyfig's Avatar
What I found out when I did this repair is that the assembly consists basically of a double wall, look closely.
Old 02-19-13, 02:32 PM
  #147
djcrx330
djcrx330's Avatar
I have studied every inch of this housing, both halves. and all along the seam. I have read the descriptions of the "vents" that others have posted. I am not sure where you are suggesting that I look. Are you suggesting that I look for a vent that communicates between the inner and outer shell? Others have described a vent that communicates with the environment outside the shell.
Old 02-19-13, 03:51 PM
  #148
kickin8
2IS/2RX/4RX
kickin8's Avatar
Originally Posted by kickin8
Noticed this last week......
Just spoke with the dealer....they said the headlights fall into the "Body" part and it will NOT be covered under warranty.....WTF???
Old 02-19-13, 03:55 PM
  #149
GadgetmanN
GadgetmanN's Avatar
I circled the two vents in your picture. They are not white on yours, but they pop off easily. But no reason to take them off. Just dry it all out and seal the seams along the edges of the housings.
Attached Thumbnails *MERGED THREADS*: Headlight Condensation includes DIY instructions (See Post #19)-photo-3.jpg
Old 02-19-13, 04:03 PM
  #150
kickin8
2IS/2RX/4RX
kickin8's Avatar
same problem here....just spoke with lexus care and they told me I have to go to the dealer for a quote before they can do anything....how stupid is that???
Quick Reply: *MERGED THREADS*: Headlight Condensation includes DIY instructions (See Post #19)
