*MERGED THREADS*: Headlight Condensation includes DIY instructions (See Post #19)
#226
After taking both out to seal the snot out of them, the driver's side is developing condensation again... I'm really kicking myself for not sealing the ballast compartments while I had them out... could there be any other area water is getting in? I did take it to a carwash (manual, not automatic), but I didn't use an excessive amount on the headlights. I noticed the condensation the next day. The lights were dry following the carwash. Not looking forward to pulling it apart again. Since mine has AFS, I'm not in a hurry to buy replacements, either. Of course, it's outside of the replacement program period.
#227
I know this is a old thread; but; I now am getting moisture on the inside of my drivers side headlight assembly(xenon hid unit self adapting and self leveling(afs) and wonder what i can do. I picked up my 07 rx350 used a little over a year ago; and a few days ago after running it through the wash; now i am getting moisture on the inside of the drivers side assembly. I know there is no way I can get lexus to replace it unless there was a recall or something on it? please help here as i dont want my light to short out at which point im really screwed. thanks matt.
#228
![Thumbs down](https://www.clublexus.com/forums/images/icons/icon13.gif)
So today I was filling fuel in my RX, I noticed that the front passenger headlight had water in them. I am going to call the Lexus dealership tomorrow, but was searching this problem and it seems like a very common problem. By chance should I try to get Lexus to fix my issue for free, or has anyone tried and get the problem done for free? You think a headlight assembly (especially from Lexus) would have zero issues and last as long as the car lasts. Also should I be worried about any potential electrical damage from the water?
#229
#230
Mandyfig, I really think these photos would help me in my quest to repair my own headlight condensation problem, but for some reason they are all blurry. Is there any way you could repost??
#231
I am sorry my photobucket account is no longer active. I have the original pictures saved somewhere. I will try to look for them and if I find them, I will email to you.
#233
I want to give a big thanks to mandyfig for his DIY.
The ballast in my wife's 2004 RX so I needed to finally tackle removing the light and replacing the ballast and sealing the darn thing up.
The DIY gave me the hints and visuals I needed to man up and do it myself.
Couple tips. The bolts on the lower bumper and the headlight bolts are 10mm. Buy replacement plastic bumper clips ahead of time, age and engine heat make them very brittle. Also, the machine screws that hold the ballast in its case will be totally corroded so get yourself four #8 3/4in machine screws.
Mike
Mike
08, 2002, 2004, 2008, 330, 350, 400, assembly, condensation, dealer, drier, es, es300, es350, fog, good, gs, hair, head, headlamp, headlamps, headlight, headlight condensation, headlights, housing, inside, lamp, leak, leaking, leaky, lexus, mandyfig, moisture, problem, question, repair, replacement, reseal, rx, rx330, rx350, safely, sc300, sc400, sienna, stop, toyota, unseal, water
