Disconnect Battery Sunroof trouble?
Due to my stupidity, giving relatives navi and reverse camera demo's with the headlights on the engine off I ran my battery flat. Then I unplugged it..
The rest of my settings seem to have restored themselves, the sunroof has not.
Tilt and open close can now be operated by either the tilt or open close button?? Both buttons do the same thing?
When I hold down the unlock button on my key fob my windows go down, but my sunroof doesn't open? It used to do this. The same applies when I put my key in the door lock and turn it..the windows go up but the roof doesn't close.
Anyone have a suggestion??
Ybaker60 (03-01-21)
You need to reset the sunroof. The procedure has been posted here a few times, but from memory,
I believe you just turn the ignition on and depress and hold the tilt button until the sunroof cycles up, down, slides open and then slides closed. Then release the tilt button and all should be well.
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
thanks dave.. I swear i searched with those exact terms yesterday?? I also tried moonroof! Anyway..cheers!!
Back in perfect working order..god bless clublexus.
jtbmoore
GX - 1st Gen (2003-2009)
12-21-05 03:35 PM
