2006 RX330 AWD - How much gear oil to use?
I am planning on doing the rear differential and transfer case oil swap tomorrow and am not sure as to how much of the oil I need to use in both cases. Of course, I can go by touch and fill as far as filling it up to the fill hole and measuring the amount I drain and fill in the same. I saw on this forum that some suggest that 1 quart is all both mechanisms take. Oddly enough, a local Lexus parts manager told me they take two quarts each? Does he mean for a flush and fill, maybe, as opposed to drain and fill?
1.0 qt each is correct... 80w or 80w-90 GL5. your dealer may have confused it with a different vehicle or something. i doubt he was referring to a flush... of course its always good to have an extra bottle on hand
Thanks. That's what I thought. Strangely, I was calling a Service department and a lady there after hearing my question transferred me to Parts!? Would not Service dept know this stuff?
I just did the rear diff and the transfer case drain and fill. Boy, was the fluid awfully dark with drain plug magnet in all sorts of goo. Glad I did it. I used Amsoil synth gear oil. Both places took one quart each. I'll let you know how it performs but I am sure I won't know much difference as my wife does not drive aggressively enough or tows. Will be checking for leaks, just in case, as I heard a switch to synth might do that.
There're two separate holes on both the transfer case and the rear differential: one for drain and the other for fill. Both mechanisms take 1 quart. There isn't really a DIY for this that I used but I needed to use a hand pump to get the fluids in up to the fill hole's edge on both. I snapped some photos from under the car which I'll try to post tomorrow.
Salim
I thought the same. Well, the first dealer's Parts guy gave me the wrong information and then even said that they do not sell gear oil. The second dealer's Service manager actually put me through to a mechanic who told me what amounts to use. Go figure...
DIY pics would be really nice....
Plug for the service manual: Expensive as they are, but are very useful for DIY
Salim
what kind of wrench did you undo the transfer case drain plug? My mechanic (non-dealer) said there must be some special tool, he didnt touch it because was afraid to strip the head
5W40
06-04-21 03:27 PM
skyline03
RX - 3rd Gen (2010-2015)
02-05-18 12:44 AM
