How do you program the garage door opener?
Old 07-12-09, 04:52 PM
sheparker
sheparker's Avatar
Default How do you program the garage door opener?
I just purchased a previously owned 2007 RX350. There was no owners manual with the car. How do you program the garage door opener? Also, any suggestions about where the locking wheel key is located? I have searched every cubbyhole and the area where the jack is kept to no avail.
Old 07-12-09, 04:58 PM
humanoid
humanoid's Avatar
While holding your remote button on the original remote, press the button on the car remote for about 30 seconds and release. The car remote should then have learned the home remote code. Works for non-rolling or rolling codes. Our garage door opener installer taught me this nice little tip.
Old 07-12-09, 05:10 PM
sheparker
sheparker's Avatar
Thanks! I will give it a try. I tried something similar with no luck earlier today. Does the car have to be in "acc" or on?
Old 07-12-09, 05:13 PM
humanoid
humanoid's Avatar
Nope, IIRC, I didn't have the keys in the ignition.
Old 07-13-09, 09:23 AM
Rainbird
Rainbird's Avatar
Wheel lock info:
https://www.clublexus.com/forums/rx-...-lock-key.html
Old 07-13-09, 11:11 AM
968racer
968racer's Avatar
You may have to have your garage door opener learn the code that is already programmed. For my rolling code opener, I pressed & held the button for 5 or 10 seconds until it flashed fast. Then pressed the open button on the car until the light bulb on the garage opener flashed.
Old 07-13-09, 12:17 PM
mandyfig
mandyfig's Avatar
Owner's Manual has details of procedure.
Old 07-13-09, 12:50 PM
mowmow
mowmow's Avatar
Ok Once and for all here is the direct instruction from Homelink's website so this will clear any confusion
http://www.homelink.com/programming/programming.taf
Mod, sticky ?
Old 07-03-23, 11:47 AM
MikesLexo
MikesLexo's Avatar
Mod, sticky ?
lonk doesn't work, new link ?
SJM (07-05-23)
Old 07-07-23, 12:28 AM
DennisMik
DennisMik's Avatar
Here is the procedure from the 2007 owners manual attached in pdf form
DrDoom78
NX - 1st Gen (2015-2021)
04-25-24 09:45 PM
E36M3
10-22-12 04:41 PM
jmerc6
08-13-12 03:03 PM
LexFather
12-06-10 08:55 PM
Quick Reply: How do you program the garage door opener?
