IS300 wheels on RX330 ?
Hi,
I did a quick search, and the closest result that I got is SC430 rims on RX330. As well, that thread did not provide a definite answer.
I'm curious if rims from 01-05 IS300 will fit my 04 RX
The spec on these rims are 17x7 with 50 offset
I understand that the stock RX rims are 17x6.5 with 35 offset
I will use 225 65 17 (stock) RX tires on the new rims.
My only concern is whether if the new setup will rub the strut tower inside. Please let me know. Thank you.
Check tirerack.com, usually will give you answers.
