LED devils eys and angle eyes (head light change)
Old 09-08-09, 05:05 PM
voodoojc
voodoojc's Avatar
I just installed bi-xenon projectors on my bike. Going to put them in my RX replacing the highbeams when I have time. This way I'll have two projectors on each side for low beam and the ones I put in will also have high beam.
Old 09-09-09, 05:00 AM
veleno
veleno's Avatar
all bikes should come standard with HID
Old 09-10-09, 09:18 AM
HimSelf
HimSelf's Avatar
voodoojc:
Do you have a wiring diagram for the bi xenon setup in a RX330? Have you found an after market headlight system that has bi xenon setup for RX330?
I'm researching on how I can convert my 2004 RX330 and have no luck finding anything. I don't want to open up my current headlight by putting it in the oven because there is a high change the plastic tabs will melt before the glue.
If you share any info that would be much appreciated.
Old 09-10-09, 12:26 PM
voodoojc
voodoojc's Avatar
Very unlikely anyone will come up with a bi-xenon setup since there are separate hi and low beams. It may be possible to retrofit a bi-xenon projector into the low beam area and use the current high beam just to flash people, like on BMW 7 Series.
Old 09-10-09, 02:53 PM
mowmow
mowmow's Avatar
Originally Posted by HimSelf
I don't know if I want to put my headlight in the oven to open it up. I tried to open a head light for VW Rabbit and ending up melting the tabs.
I need to hook you up with my retrofitter. He will be the one to do it right for you and it will look very very OE, retain your AFS and do the strip of LED DRL like you want as well as quad projector setup. Full machine mount means the projectors are fully adjustable from inside. I had a set of Quad projectors myself on my Scion tC and a strip of superflux amber led on the eye lid for turn signal
email: littodevil@gmail.com and let him know Ian sent you. ps his work is not cheap but the wow factor is going to be crazy.
I'm going to add my old retrofit's write up link in my signature so others can see the details involve in retrofit the way it should be instead of the hack and slash or the ebay crap.
Old 09-10-09, 11:23 PM
someboy
someboy's Avatar
i been looking to installing AAC 8k halos into my is350 headlights, but no luck finding anybody that knows how to do it.
Old 09-11-09, 08:37 AM
HimSelf
HimSelf's Avatar
Default easy way
The easy way is to buy an after market head light unit with the halo eyes and then buy the thine type led lights and put it between the head light and the bumper.
I'm looking at a few on ebay. If you are interested maybe we can do a group buy and get a discount.
Let me know I'm planning to do this within the next two weeks since the ewather is getting cold here in Ottawa, Canada.
Old 09-12-09, 12:44 AM
mowmow
mowmow's Avatar
Email Littodevil, he will probably know.
Old 09-12-09, 12:49 AM
mowmow
mowmow's Avatar
Ebay ones are the worst one you can spend money on. The projectors are crappy, zero quality control and they go out so fast, it's a waste of money
I've seen so many guys in other forums buy ebay headlights and complaint
like hell about the cheap quality.
Bottomline is you'll get what you paid for
Old 09-12-09, 02:02 PM
veleno
veleno's Avatar
mowmow, how much did your retrofitter charge you for the TC headlights?
Old 09-15-09, 04:08 PM
mowmow
mowmow's Avatar
It was not cheap cos it's labor intensive as well as the time it took for design. The cost was in the mid $3000 range. I did sell it to my friend for almost $3K when I trade the tC in for the RX
williakz
10-10-22 11:49 AM
Chavez562
02-28-17 04:05 PM
Stoodo
HS 250h Model (2010-2012)
18
04-07-13 08:17 PM
Mancebof
01-05-12 08:50 AM
07-22-06 07:06 PM
Quick Reply: LED devils eys and angle eyes (head light change)
