headlight wireing questions
Need some help to rewire my HID kit.
I have a 2004 RX330 with Xenon. I am changing my high beam to Xenon also and I will readjust the high so it would be the same or a little lower then my normal headlight. I know I will loss my high beam and I am ok with that (later I will buy a lens kit that has a motor inside to switch between low beam and high beam)
My question is:
How can I wire it so the modified high beam comes on with the low beam automatically?
Do I need to change my fuse to a higher amp?
Is there enough voltage and amp to run both lights or would I get flickering problem?
How would my alternator or battery handle this modification?
Thanks
My question is:
Thanks
KC98LS
12
12-18-20 09:42 AM
