RX350 2008 Electronics Control
Dear All Just bought RX350 2008 I have some questions for you guys:
1- How to disable the auto door locks when car starts moving?
2- How to disable the steering auto movement with entry and exit?
3- How to check the tire pressure?
4- How to close the mirrors using the remote control when locking the car?
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
3 - use a tire gauge??
4 - I'm not 100% sure but I don't think you can close the windows with your remote. Should be able to use your key plugged into your do though.
Thanks for the reply
in my previous Mercedes and many other cars you can setup many configurations from your screen and also can see the tire pressure in each tire 2 bad not available in the RX
So there is no secret menu in the Nav screen to program anything?! anyways what will the dealer do is it a secret :P or they use a special computer with an interface?
I tried the trick to override the Nav volume touch ul dl ul dl but unfortunately it did not work ((( maybe because its a new version i don't know so does this mean that i have to install a module or something?
I really wanna make the DVD movie to work on the move for my kid
If you are talking about the windows, then the previous poster is correct, the only way to close the windows from outside the car is to insert the key in the door lock, turn it to lock and hold it while the windows roll up.
