Lexus RX330 Spark Plug
hey guys: I am new and i hope i can get some help with what i need.
I need to replace the spark plugs in my car. What do ya'll recommend get them from the dealership or from autozone. Usually they are more expensive at the dealership but i want to make sure they will be the same. I would appreciate your advice.
Thank You
Thank You
Thank You
Thank You
NGK or ND Iridium plugs.
How many miles on the current plugs? I had ours replaced at ~90K (along with the timing belt) and they looked to be in excellent shape.
Spark Plugs, if you read the manual are not scheduled for replacement until 100K (?).
Why are you replacing them?
Check the manual for recommendation of the spark plug make and model.
Denso SK20R11
NGK IFR6A11
1.0 to 1.1 mm gap on new.
NGK IFR6A11
This is for RX330.
