P0156 Check Engine Light
(2004 RX330) Where is this sensor located? I see one in the engine bay and one under the car. P0156 back 2 sensor 2. Also anyone know the part # both for Toyota and Lexus?
codes which start with "P" are standard across the board codes for ALL vehicles.
there fore they all have to mean the same thing. that is a standard picture, therefor it will be the same for yours.
alternatively you could just go to the dealer parts dep. and ask them for a bank 2 sensor 2 O2 sensor, and they should be able to get it for you. (or get one of the service advisors to ask a mechanic)
Well I went yesterday morning to ask the parts guy at Lexus and he told me that they dont go by "sensor 2" and that bank 1 is in the front and bank 2 was in the rear. Which is oppisite of what everyone else has said.
I'm trying to find a good diagram for you.
*I need to repost the pictures*
This is for Heated O2 sensors.
REMOVE NO. 3 EXHAUST FRONT PIPE SUB-ASSEMBLY (for Bank 2)
(a) Remove the 4 bolts, 2 nuts, 2 compression springs and No. 3 exhaust front pipe sub-assembly.
REMOVE EXHAUST FRONT PIPE ASSEMBLY (for Bank 2)
REMOVE OXYGEN SENSOR (for Bank 2)
Hope that helps
It looks like it's located in this pipe.
SST: 09224-00010
Torque: 44 Nm (449 kgf-cm, 32 ft-lbf)
Okay, here is a good diagram to give you the general location.
Hope that helps
SST: 09224-00010
Hellojenna
RX - 1st Gen (1999-2003)
08-03-17 08:58 PM
ivie08
08-21-10 10:24 PM
