RX330 high beam lights inop
Old 07-11-20, 12:00 AM
Bigvin
Bigvin's Avatar
Default High beam /drl not working
Originally Posted by cbo111
Will do. I think I may try replacing the DRL relay. Should't cost more than $40 I hope.
i have same problem but high beam switch pulled back turns on low beam then pushed foward no high or low beam.
Old 07-11-20, 12:21 PM
biopete
biopete's Avatar
interesting. So u have no head lights at all on normal switch ? Check the wiring diagram.
is it the case that most cars disable high beams when fog lights are on? I thought that was how one of my old Mercedes worked.
Old 07-14-20, 12:39 AM
iMSQ
iMSQ's Avatar
Originally Posted by biopete
is it the case that most cars disable high beams when fog lights are on? ...
Yes.
PS: I would always start with bulbs replacing if high/low beam doesn't work.
Orcala
RX - 1st Gen (1999-2003)
04-26-13 02:05 AM
MERXUS
SC- 1st Gen (1992-2000)
08-18-09 11:44 PM
cpone
Lighting
20
09-19-06 01:42 PM
yoshi13
11-16-05 01:58 PM
Quick Reply: RX330 high beam lights inop
