Power windows dead - RX330
My front passenger window and rear windows are dead following battery replacement on my 04 RX330. I've searched this forum and read all about power cycling the windows after battery replacement but I can't do that because there is no power. I've checked all the fuses. The drivers window works just fine. Key in the door, turn and hold only raises/lowers the drivers window. This wouldn't be urgent if one of the windows wasn't stuck in the down position! Help please!
you need to cycle the windows in the following order using the switch on the door itself (not the master switch on driver door):
driver's
passenger front
passenger rear
driver's rear
moon roof
You're supposed to lower then raise (resets the electronic travel stops). In your case, just raise, lower, re-raise. Once a window is done, the switch on the door next in sequence flashes until you reset it and so on...
As you're finding out, none will work until they are reset in order...
Good luck
driver's
passenger front
passenger rear
driver's rear
moon roof
Good luck
So did you get it resolved? You ok now?
Found a dead battery this morning, didn't have time to go to dealer so I replaced it and realized the sunroof and windows driver panel wasn't working correctly. Found this thead and got the answer I was looking for. Great website
Thank You so much for the information. I had to change the battery for a friend and knew nothing of the associated things that could go haywire. All is well. This is my first post. Took 15 minutes to sign up but I had to say "Thanks".
Great info, thanks.
driver's
passenger front
passenger rear
driver's rear
moon roof
Good luck![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
driver's
passenger front
passenger rear
driver's rear
moon roof
Good luck
The manual has most, if not all tricks on re-setting your powered assemblies.
I have a new battery for the RX I am installing tonight and this came about, which is simply great.
