Please Help- 04 RX330 HID Headlamp????
Mike,
Saw your posts on another owners issues with their lamp as well. I just went through the same thing. When I switched bulbs I found out they were fine! And that it was the "headlight computer/ballast" whatever you want to call it. Dealership specifically stated that this IS covered under the extended warranty and have replaced it. Some may give you issues with the "condensation". This is usually BS. My dealer also said that excess condensation that would NOT burn off in 15 minutes is Lexus standard. FYI, when I turned on my high beam it burned it off in 3-4 so that rules out that condensation was the issue. Lastly, I was just on another post (somewhere) and there were pictures with step by step instructions to remove the light. Hope this helps.
