Installing an ipod in the center console
I am trying to install an iPod kit in my 2009 RX350 (no nav.) I got the kit working and was able to thread the ipod cable to the glove box. I am trying to see now if I can move it to the center console box instead which is a more convenient location.
I am guessing I can thread the ipod cable from the back of the radio assembly straight down to the floor and bring it under the lower console cover into the console. To do this I need to remove the console to get the wire under the console and thread the wire through a new hole in the rear console compartment. I found some instructions here how to remove the center console. How do I remove the two side left and right side plastic panels that go from the floor up to the radio panel?
Any experience installing an ipod in the console?
No, I don't play soccer!
My Vais unit is located in the empty space underneath and forward of the shifter which is I believe what you're trying to get to. There are two plastic screws on the upper part of the panels. Once they're out, grab the panel and slide firmly toward the engine. You might need to bend slightly but not too much. There are plastic tabs on one side that can be damaged/broken if too much force is used.
My installer did the work but if you're thinking about running the iPod cable in the console between the seats, you need to remove one of the seats. He ran the cable under the rug through a hole he cut in the console. He had to remove the plastic insert. I say keep the cable in the glove box. If something happens which did with me, you can change the cable easily.
Good luck.
Good luck.
